Configures the mode of operation for ESRP on the switch.
| extended | Specifies ESRP extended mode for devices running both non-Universal and modern NOS versions. |
| standard | Specifies ESRP standard mode for devices running modern NOS versions. |
The default mode is extended.
The following command configures ESRP to run in standard mode:
configure esrp mode standard
This command was first available in ExtremeXOS 11.0.
